Set new Coord Sys as "Master" for STL output?
ptc-2105142
Is it possible, to set a user-defined Coordinate System as the XYZ master so when I open the exported STL file in my CAM program, it registers the part's XYZ axis' according to my defined Coord sys instead of the DEFAULT_CSYS at the top of the model tree? I don't know the exact angles to offset the part in my CAM software, and figured it would be much more fool-proof to create a new CSYS and use that to align my model.. as opposed to eyeballing it in my CAM software. ... having no luck thanks all ~Steve
FIGURED IT OUT! yay it's an option in the STL save dialogue box, to select coord system. great, there is a time crunch today, now I'm back on track. ~Steve
