Setup color
MB_9203282
Setup color
I am using Creo Parametric Release 10.0 and Datecode10.0.5.0
I would like to know more about coloring surfaces.
I design plastic molding tools and the customer wants the models colored in different colors, for example iso hole yellow inch hole purple.
Now I have to sit and change everything manually
can it be done so that I have it controlled in the config file
is it possible?
Do you have any good basic information then can I make my own setup
tbraxton
22-Sapphire I
(To:MB_9203282)
I am not aware of any config options to support your objective. There are Creo Toolkit apps sold that are made to apply colors: Rule-based color coding with SMARTColor - B&W Software
If your requirement is not sophisticated, then you may be able to handle semi automation of this process using layers and rules without buying additional software.
Involute Development, LLC
Consulting Engineers
tbraxton
22-Sapphire I
(To:MB_9203282)
https://community.ptc.com/t5/3D-Part-Assembly-Design/New-to-Creo-and-visual-cosmetic-threads/m-p/985945#M137433
I haven't already had the time to create the mapkeys but if u 'll be able to obtain a good result please share the mapkey
Hi @MB_9203282 ,
It appears that this https://community.ptc.com/t5/3D-Part-Assembly-Design/Setup-color/m-p/988952#M137700 answers your question.  For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
