Setup color
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Setup color
I would like to know more about coloring surfaces.
I design plastic molding tools and the customer wants the models colored in different colors, for example iso hole yellow inch hole purple.
Now I have to sit and change everything manually
can it be done so that I have it controlled in the config file
is it possible?
Do you have any good basic information then can I make my own setup
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I am not aware of any config options to support your objective. There are Creo Toolkit apps sold that are made to apply colors: Rule-based color coding with SMARTColor - B&W Software
If your requirement is not sophisticated, then you may be able to handle semi automation of this process using layers and rules without buying additional software.
Involute Development, LLC
Consulting Engineers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I haven't already had the time to create the mapkeys but if u 'll be able to obtain a good result please share the mapkey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @MB_9203282 ,
It appears that this https://community.ptc.com/t5/3D-Part-Assembly-Design/Setup-color/m-p/988952#M137700 answers your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
