Shaded views and layers
mpeterson
Hello ProUsers,
I have been having problems with controling layers in views that are shaded. I turn off all layers for curves and surfaces on a shaded view, but the curves still show. I try to control the layers of the shaded view individually and it doesn't hide the curves either. Are layers controlled differently in shaded views or are there hidden tricks to this or is there a bug? I have been using WF5 for a year and currently on build 50. Please advise if you have any insight or recomendations. Thanks!!
Mark A. Peterson
Sr Design Engineer
Igloo Products Corp
1 REPLY 1
It sounds like the same bug I see in WF4 M080. The fix (temporary as it
will return eventually) is to go to layers, settings menu and pick
'Drawing Layer Status'. Then simply say OK in that dialog. No need to
change settings. Assuming your curve layers are off, they should
magically disappear then.
Later, they'll be back and you'll have to do it again.
Doug Schaefer
LinkedIn
