Shaded with Edges Not Activating as Default
JR_10680659
Every time I open the model, the view changes back to "Shaded" even though I have "Shaded with Edges" selected as the default. I'm running Creo 10.
tbraxton
(To:JR_10680659)
Open the Creo options after you start Creo and check the in session setting of the config option "display". You probably have a config option being read when you start Creo that is causing this, or you have not saved this option to a config that is being loaded when you start Creo. If the option is not set as shown below, then correct this and test the behavior after the change.
Config option:  display shadewithedges
Involute Development, LLC
Consulting Engineers
tbraxton
(To:JR_10680659)
That did it! Thank you!
