For the sheet metal drawings, when I make flat state view in the drawing, it is two lines at the bend. but for simple representation, i need to have only single bend line.
You need to show the axis that is created.
Thanks @andy,
Will it be any possible way to get the axis to be generated automatically when I create Flat State or Flat Pattern.
I dont think so since it is a model annotation...I could be wrong though.
It is already there in in the model when you create the flat state. You just have to show it in the drawing.
You are not creating an axis, just showing it.
Thanks Andy & Stephen,
Extended reply please need your inputs... In the figure shown below... can it be possible to hide the lines and need to have the axis visible.
As you can see... I need to have only axis line... but the other lines which are light gray color... i wanna hide it.
double click the drawing view, click on view display option, and then select "none" under tangent edges display option.
Thanks Rohit, Andy & Stephen...
I am very happy to have my query solved in less than 24hrs.
Thanks all... Hope to come acros with another question.
Nasrullah.
