Showing derived dimensions
AnkurAggarwal
Hi All, I created machined model from casting model using merge feature and created some cuts (machining operaions) over that. Now while creating drawing of machined part, I want to show dimensions which are derived from original casting model. Can I show those dimensions? Ankur.
Yes, you can. show and erase-dimension-by feature and view Now move the mouse to the feature you want. A feature will be highlighted, probably one of the machining or the merge feature. Keep an eye on the message line and click with the right mouse button until you reach the feature you want.
Thanks Klaus.
