Is there a way to show trailing zeros in the model? We use annotations to show dimensions on our parts we send to vendors, but not being able to show the trailing zeros is causing problems, 10.3 is a lot different than 10.30 when it comes to conveying our tolerances.
LEAD_TRAIL_ZEROS_SCOPE only works on the drawing.
Is there a way to show them?
I don't know about other versions, but Creo Parametric 2.0 allows you to set detail options in the model. Go to File > Prepare > Model Properties, and at the bottom of the dialog is "Detail Options"; click "change". You get essentially the same dialog as you get in drawing mode to set detail options; lead_trail_zeros is there and works the same as in the drawing.
YES!!! Thanks for the help!!
