I'm trying to create a silent install for Creo 2.0 M160 and all the client side components. I'm getting an error on the CreoView Express install:
Invalid Switch - "/vADDLOCAL="ALL""
The syntax for calling the installer in my batch file is:
start /w "\\server\creo_install_files\creo_2_m160\pvx32_64\CreoSetup.exe" /vADDLOCAL="ALL" /qn
This matches what is in the install guide for Creo 2.0 M080. I do not have the install guide for M160, but the install guide for Creo 3.0 F000 shows the same syntax. I assume the Creo 2.0 M160 syntax should be the same.
Any insight as to what I'm missing?
Figured it out. There are no quotes around the path to CreoSetup.exe:
start /w \\server\creo_install_files\creo_2_m160\pvx32_64\CreoSetup.exe /vADDLOCAL="ALL" /qn
not
not
Is this for Creo or Creo View? I use that for Creo View.
You can also add this at the end to define the installation directory:
APPLICATIONFOLDER="C:\xxx"
Here are all the options.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS32319
CreowView Express that comes with a Creo install.
Here is the code I use. When you use start with quotes, you need a title in quotes first. I put in blank. This is preferable, in case you have a space in your path.
start /wait "" "%InstallViewExpress%" /vADDLOCAL="ALL" /qn APPLICATIONFOLDER="%creo_load_point%\View Express\"
