Slow screen handling in drawings
japrenticeuk
Greetings
I have a user with a laptop screen handling problem. In drawings, if one
drags a view or even a dimension, it is as if the drawing sheet is covered
in treacle. The view follows the mouse but lagging far behind. When you stop
dragging the view catches up after a second or so (if a simple view).
Model and Assembly screen handling is fine.
It is as if all the lines are being redrawn for every pixel moved in the
drag.
I have tried adjusting graphics 3D Acceleration from Fast to High Quality
with no change.
System is a bit odd: ASUS laptop Intel Graphics with Win 7 x64 running 32
bit Wildfire 4.0
I am reluctant to update the graphics driver as it is hard to identify which
one to use. Machine is new.
Anyone seen slow dragging and got a config option to fix it? Machine will
only be used on small assemblies.
John Prentice
0 REPLIES 0
