Solid model tolerance gap
caimonetto
2-Explorer
I'm working with Creo 3.0. I'm drawing molds for a client. My client tells me that the delivered files are not solid but I see them solid. He tells me that their CAM system needs solid models with 0.01mm tolerance. How do I set this tolerance? for single parts ? for assembly or just for exporting ?
8 REPLIES 8
pnos
(To:caimonetto)
StephenW
(To:pnos)
I don't think I agree with this. Accuracy is not the same as tolerance.
pnos
(To:StephenW)
I think so
caimonetto
2-Explorer
(To:pnos)
Thanks but I found the default_abs_accuracy parameter where you can enter the value of 0.01mm. I think the answer to what I wanted.
caimonetto
2-Explorer
(To:pnos)
But how did you get absolute accuracy? I only relative accuracy option on the field show in your photo.
pnos
(To:caimonetto)
Thanks Pepa Nos, but I do not find the absolute accuracy option. I had to activate  the variable "enable_absolute_accuracy" on yes.
pnos
(To:caimonetto)
Perhaps I helped
