Solidify ..can i make it default to Remove Material instead of Fill with solid?
dunebuggyjay
Hi Guys,
Is it possible to make certain settings within a button default?
For example. Solidify. I want this to always default to Remove material when i click on it. Is this possible.
There are many other buttons that i would like to set certain options as a default too.
I know i could make a map key, but was wondering if there was another way to specify default settings within an function.
Jay
I'm in Creo7.0.2.0  if this matters.
1 REPLY 1
tbraxton
(To:dunebuggyjay)
It may possible using Toolkit or one of the other API to create custom UI elements. There is no provision in the UI configuration tools available to a user without programming that can do this that I am aware of.
The best option without a custom app using an API is to create a map-key and add it to the UI where you want it with an icon in the GUI. I have done this for certain measurement tools to streamline workflow and it works nicely with most things.
Involute Development, LLC
Consulting Engineers
