Solidify problem!!!
hmr
Solidify problem!!!
Hello All,
I am in need of suggestions
I have a requirement where in I have got a step model(Import feature) of an assembly, which is in surface form & I would like to solidify it. Can anyone suggest me some best method in doing this???
Best Regards,
Harish
2 REPLIES 2
dveljkovic
(To:hmr)
This will help you to start:
http://learningexchange.ptc.com/tutorial/805/using-the-import-datadoctor-to-fill-gaps-remove-and-create-surfaces
You have to use IDD in order to fix imported step file. When imporintg the STEP file (or any other non-Creo file) select EXTERNAL for "model accuracy" under MODEL tab. This will bring step file accuracy into creo model.
gkoch
(To:hmr)
Danilo and Steven have provided two good hints, but I noticed you mention importing an assembly.
Assemblies are probably handled slightly different between CAD systems, but in most cases I would expect multiple closed quilts to be imported (or almost closed quilts, needing fix).
You can import a STEP assembly into assembly or part mode, but assembly mode is preferable, because you can handle each part of the assembly separately, opening it from the assembly tree.
If you need all geometry in a sinle part, you can still merge the completed parts in assembly mode.
