This post is solely for the love of proe
There are many things which solidworks cannot do..but which proe can do and solidworks is trying to catch with every release...
We cannot sweep on both sides of the guide curve in solidworks....if the section is in the middle..
This feature will be added in solidworks 2016
What we proe users take for granted..is not available in solidworks...
Here are a few I've found:
Is there a "restructure" command at the assy level in SW?
You can restructure through drag and drop.
Moving a part from the top assembly (constrained/in BOM) to a lower-level assy and vice-versa?
I'm not sure, I haven't played with it that much.
That's what I mean by "restructure". Not simply moving a part around WITHIN an assembly in the model tree (reorder).
Sorry, yes, I was able to move it from a sub-assy to the top level.I didn't simply re-order.
I didn't investigate what that might mean for assy mates nor did I try many combinations, I simply dragged a part out of one assy into another.
Thanks! I remember when they added that command. VERY handy!
