Sort a repeat region table
PerMobacke
I want to sort a BOM-table after the assembly tree order. Part 1 in the assembly tree should be 1 in the BOM-list, second part in tree should be 2 in bom etc. How is this done?
Go to table, repeat region, sort regions, clear all. This should give you the desired output.
Thanks, the table was sorted correctly when i cleared the sort criteria, I also had to change the attribute for the table to No Dup/Level. Only the option No duplicates didn't work.
