I'm working on some project and I'm using CREO parametric 3.0. I'm having a problem to identify the spline method implemented in Parametric 3.0. Which type of spline equation used in CREO? Is it NURBS or B-Spline curved equation or other type of spline curves?. Does anyone know or perhaps give me the link to answer this question?
thank you in advance.
regards.
Google is your friend:
https://community.ptc.com/t5/PTC-Mathcad-Questions/ProE-Spline-Equation/td-p/279104/page/2
It's possible you won't need to know this if you share the reason for wanting to know. Some other method may be easier.
thank you for the reply dschenken.
the reason I want to know the type of spline because i want to make a Spline feature in Creo as my reference and it required to know the basic equation of the feature.
thank you once again.
