Split tree between model and layer
kdirth
Is there a way to view the model tree and the layer tree at the same time in CREO 2.0?  Ideally this would be a split column similar to how in drawing you can see the drawing tree and model tree.
Kevin
(To:kdirth)
You can't split it but you can separate the layer tree so it displays in it's own window using the option floating_layer_tree..
Kevin
(To:kdirth)
