Step file into Pro Eng Wildfire 2
ptc-3024634
I just brought in a step file, of a round gear like shape into Pro Eng. The top and bottom are flat surfaces. The rest are shaped. How do I add datum planes to the part other then the flat surfaces. As well it does not want to reference any of the geometry. So how do I take this step file back down to a sketch level or create a sketch so I can work on it. Thank-you
In the feature tree move the red arrow before the import feature and pic the create datum plane command. Pro E will install three datum planes.
