Step file origin
sstrehlow
Step file origin
Is it possible, in Creo-2, to find out what the native software a step file was made in is?
mganzer
(To:sstrehlow)
Like this in text editor:
ISO-10303-21;
HEADER;
FILE_DESCRIPTION((''),'2;1');
FILE_NAME('3241288-001','2015-05-05T',('mganze01'),(''),
'PRO/ENGINEER BY PARAMETRIC TECHNOLOGY CORPORATION, 2014000',
'PRO/ENGINEER BY PARAMETRIC TECHNOLOGY CORPORATION, 2014000','');
FILE_SCHEMA(('CONFIG_CONTROL_DESIGN'));
ENDSEC;
DATA;
4 REPLIES 4
Not directly in Creo, but if you open the STEP file in a text editor (WordPad should do) I believe the creator software is often listed in the first few lines.
mganzer
(To:sstrehlow)
ISO-10303-21;
HEADER;
ENDSEC;
DATA;
Hi Shawn,
Did the reply from mark answer your question? If yes, please add your comments to post and mark the reply as correct answer.
sstrehlow
(To:Mahesh_Sharma)
Thank you for the help, this answered my question.
