Is it possible, in Creo-2, to find out what the native software a step file was made in is?
Like this in text editor:
ISO-10303-21;
HEADER;
FILE_DESCRIPTION((''),'2;1');
FILE_NAME('3241288-001','2015-05-05T',('mganze01'),(''),
'PRO/ENGINEER BY PARAMETRIC TECHNOLOGY CORPORATION, 2014000',
'PRO/ENGINEER BY PARAMETRIC TECHNOLOGY CORPORATION, 2014000','');
FILE_SCHEMA(('CONFIG_CONTROL_DESIGN'));
ENDSEC;
DATA;
Not directly in Creo, but if you open the STEP file in a text editor (WordPad should do) I believe the creator software is often listed in the first few lines.
ISO-10303-21;
HEADER;
ENDSEC;
DATA;
Hi Shawn,
Did the reply from mark answer your question? If yes, please add your comments to post and mark the reply as correct answer.
Thank you for the help, this answered my question.
