Steps taken to confirm that WF 4 doesn't overwrite WF 3 files.
jgfrankusa
Pro Gurus:
Below are my first step to confirm that WF 4 doesn't overwrite WF 3 drawing
format, library parts, start parts and start assembly. Please let me know
if there is something that I might overlook.
Thanks and happy Friday
Frank
- - Backup the a current WF 4 assembly to a server working
directory.
- - Delete the library parts MS15795.prt and MS51957.prt from the
working directory.
- - Bring up the new_motherboard.asm.1 in WF 4
- Delete the instance MS15795-802 from model tree - Re-Insert
MS15795-802 and insert MS51957-15 to the assembly then save.
- - Monitor the standard library folder and make sure that WF 4
doesn't overwrite these WF 3 parts back to the folder.
- - Detail the new_motherboard.asm using WF 3 drawing format and
make sure that WF 4 doesn't overwrite it.
- - Create a new startpart and startassy and make sure that WF 4
doesn't overwrite these WF 3 templates.
There are no changes or new files have been created in these
correspondent folders.
all
A
A
On Thu, Dec 8, 2011 at 2:22 PM, Doug Schaefer <-<br/>> wrote:
> Setting the files themselves to read only won't help since Pro/E creates a
> new file at each save and those new files are the ones that Pro/E 'sees'
> when browsing a folder.****
> *Doug Schaefer
> *Senior Project Engineer, Mechanical
> *Design Central*
> www.design-central.com****
> 614.890.0202****
> *From:* Frank Giovani [
> 3? Will there be any risk that WF4 overwrite WF3 drawing template and
> common library parts?"****
> Pro Gurus:****
> Thank you all for your inputs and suggestions. Below are the responses
> that I have received. Since our company doesn't have a Pro/E administrator
> and PDM yet, the ...
There are two things that could affect your results:
1 - How the config option 'save_objects' is set. The default is
'changed_and_specified' which is fine, but if someone sets it to 'all',
I think it'll overwrite your library parts. Not sure about the other
options.
2 - If a library part gets modified. Add an axis for assembly or a
layer change and now it gets marked as changed and it'll get saved.
Doug Schaefer
LinkedIn
