Steps to creating a Top-Down Assembly
fgallagher
I have the basic understanding of how to create the Top-Down Assembly:
create master assembly
create any sub-assemblies
create skeletons
create parts
I would like to have a general feel for how much should be done with the skeletons. I have seen as little as just references to full out sketches of the entire shell of an object. For me, I am creating a weldment of a tube with steel plates welded to it. This will be one assembly, one skeleton, 7 models. I was going to create the skeleton of the tube, OD and the ID extrusion, then create the reference planes for where the plates would be welded. My thinking was we typically change the location of the plates so by putting these planes on the skeleton I would only have to revise the location of the plane to change the location of the plate for the entire assembly. Also, when doing the model for the tube, I merged the tube extrusion from the skeleton into the tube model to add further machining on this, but now the assembly goes from gray to gray with blue stripes on it. Why is this happening?
Technically, you will have a top-down dependency if you tie any part to another part through an assembly or use any "external references" from outside any individual part. Managing this is the real challenge. The optional extension is suppose to help with this.
