"Joseph Lord" wrote:
Hi There, I'm not a big user of mapkeys, but I have some set-up to colour my models different colors. If I want a part to be red, i run the 'RED' mapkey ect. I set up a new one which rotates the model to standard oreientation, change to wireframe then save as a JPEG into a folder. I want to do lots of screen shots of all our parts for a manual. After I set-up the mapkey, I can open a new part, run the mapkey, and it works (saves a JPEG to my folder). When I open the next part, I select Tools>Mapkeys, but when i select 'mapkeys' the drop down menu disapears and the mapkey diolouge box does not appear. I have to close down then restart ProE, and I can run the mapkey on the first part I open, but I can't do it on any more parts I open. Any ideas? I have experienced this on another mapkey I tried to setup previously.
Just one thing, as i am going to run out of 'F' numbers, can you set any other key to run a mapkey, ie press 'a' will run a mapkey? I take it you just put 'a' under 'Key sequence' when you create the mapkey, and do you need the '$' symbol in front of it?
"David Butz" wrote:
Easiest thing to do is go into the config.pro file where your makpeys are stored and change MAPKEY $F11 to MAPKEY jp.
@Joseph Lord I Don't think u can edit the key sequence it is better to edit new one this is an good idea
