Strange behaviour Creo view express version 2.0
Alain
7-Bedrock
Version 2.0, datecodes M020 en M040 have this behaviour.
An electrical engineer wants to view the PRO/E design files made with wildfire 4.0 but can’t load the assembly, only one or sometimes 2 components are visible.
I made a simple assembly to check this behaviour, one PCB and one component, when he loads the assembly file into Creo view express he sees only one component. (both files are in one directory and can be opened separate but not in one assembly.)
When I open the same file, I see the total assembly, 2 components. The only difference is that I have PRO/E wildfire 4.0 and 5.0 installed on my machine and he has not.
Does anybody have any idea how to solve this or what is causing this behaviour?
Cheers,
Alain
Hi Martin,
Thanks for that tip.
Attached you can find the assembly that we used to test Creo view express.
creo.zip
On my desktop and laptop (with PRO/E installed) I can view the assembly. On the laptop of my colleague (no PRO/E installation) he can see both components without no problem. This is the first assembly he can open.
The original assembly can normally be opened on my system but only the connector is viewable by my colleague.
Today I did a test again and send the files again to my colleauge and he could open them .....
When I asked him to show me the original files again that he received ..... I noticed what happened and why he could not open the first project .... he renamed some files ....
And now I sound a bit stupid
Alain
5 REPLIES 5
MartinHanak
(To:Alain)
Alain,
can you upload your simple assembly ?
Martin Hanak
Martin Hanák
Hi Martin,
I can't add any attachements, (picture or zip).
If I add a photo then I can't submit the post.
It is really a very simple assembly we used to test, a plane PCB and an elco on top. Only the elco is loaded into creo view express of my colleague who has no PRO/E installed. I see both components in the viewer.
How can I upload a zip file?
cheers
Alain
MartinHanak
(To:Alain)
Alain,
click Reply and then Use advanced editor (top right corner). Then you will see Browse button at the bottom.
Martin Hanak
Martin Hanák
Hi Martin,
creo.zip
Alain
MartinHanak
(To:Alain)
Alain,
it is nice to hear that the problem is resolved . I do not have to do any testing ...
Have a nice day.
Martin Hanak
Martin Hanák
