Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Hi everybody.
And sorry for the repeat question, but hopefully somebody can help me this time around.
I have a model of one of our castings with X, Y, and Z datums. X datum is a plane, Y & Z are axes. The datums show up on the model and the drawing just fine. From these casting models I started creating my machined models. To do this i used: Insert>Shared Data>Merge from other Model. Once the dialog box appears, I use the casting model, set it to Default location, Copy Datums, and make it dependant. So far so good. At this point, I go to Edit>Setup>Geom Tol. I go to the layer tree and select the X datum from merged model. I try to do this again for the Y & Z axes. But I see a strange note in the Layer Tree. Out to the side of what would be the Y & Z datums it says "Curve (id number) not found in part (part number)". I have attached a screen shot so that you can see for yourself. I have made several machined parts from castings by using this same method, and have not had this problem. I really don't know what else to do from this point, except for fudging the drawing. And i really don't want to do that. So please...anybody...HELP!!
We are using WF M240. Thanks in advance
