Summary: Automate Creation of empty rep?
davehaigh
Turns out I was making this more difficult than it needed to be.
When you look in the trail file, picking the top level assembly indicates that it's picking node0, so the pick is based on the position not the name of the item.
Since the top level assy is always node0 you can write a mapkey to create an empty rep.
mapkey cer @MAPKEY_LABELCreate Empty Rep;\
~ Activate `open_rep` `Define`;EMPTY;\
~ Select `main_dlg_cur` `PHTLeft.AssyTree`1 `node0`;\
~ Activate `compseledit` `DoneBtn`;
If you want to do a bunch of files, you need to use a trail file. Trail file snippet:
~ Activate `main_dlg_cur` `main_dlg_cur`
~ Command `ProCmdModelOpen`
~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`
~ Activate `file_open` `file_open`
~ Input `file_open` `Inputname` \
`C:\\Documents and Settings\\haigh1\\pro\\wf4_home\\test_assy_1.asm.1`
~ Update `file_open` `Inputname` \
~ Activate `file_open` `Open`
empty
~ Select `main_dlg_cur` `PHTLeft.AssyTree` 1 `node0`
The one thing to note here is that you need the double back slash in the path to the file.
You can use the trail-maker to create a monster trail file to do a bunch of files.
0 REPLIES 0
