Summary: Paginate Repeat Region
dgschaefer
Thanks all, I figured out what I was doing wrong.
I forgot that when setting the new extent, you need to pick twice - once for the upper left (in my top down table) and once at the bottom for the end of that segment.  The Creo UI here doesn't help.  With the message area at the bottom of the screen it's easy to miss those prompts. Also, with tooltips turned on, they obscure the last, and most important, line in the message area.
Thanks all,
LinkedIn
0 REPLIES 0
