Summary: Part interference = lines missing
dgschaefer
The consensus is that the only way to fix it is to eliminate the
interference. There were some suggestions for doing that:
* Make a family table of each part - Painful, messes up the BOM
and the parts are already family table driven, so it's even more
painful!
* Make the parts flexible in the assy - Tried to, but the length
dim is relation driven, so I couldn't
* Use weld features - Not familiar with that and don't have time
to learn it. Gave it a quick try, but couldn't make it work.
* Use "edge display" to force them to show - Novel approach, but
alas, it failed.
I'm going to try assembly features to trim the interfering parts. If
that fails, I guess I'll dive into family tables. Ugh.
Doug Schaefer
LinkedIn
0 REPLIES 0
