To answer the questions: No mechanism constraintsNo IntralinkInstance, generic and all components are in sessionSimple assembly constraints, 3 planes aligned to three planes. All 3planes in the assy are in the same component. I ended up re-assembling it in the instance and then deleting thecolumns from the table. It's what I did the first time, but this timeit worked. Odd. Thanks,Doug Schaefer This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
LinkedIn
