Sweep, merge
rubenvillarreal
Sweep, merge
Is it possible to merge a Sweep feature at the same time that you are using the multiple trajectories option?
Sweeping a solid into a solid automatically merges the two bodies.  What sweep doesn't have is an "up until" option.
Two ways to tackle this; 1) put the hole in the tube later or do it twice, 2) work with surfaces in your sweep and trim them prior to solidifying them.
6 REPLIES 6
Inoram
(To:TomD.inPDX)
adding to the tackle list.
Or, you might be able to reorder the features in the model tree.
Or, you can remove the inside pieces with Remove if you have Flexible Modeling.
Got it
Why are my replies disappearing?
Patriot_1776
(To:TomD.inPDX)
Sorry, did you say something??
