Swept Blend
Costantza
6-Contributor
Swept Blend
I have an extrude inside a box (like a mold). Is it possible to surround this extrude with the Swept Blend function and then remove the material around it?
StephenW
(To:Costantza)
You are going to have to include and image or and example of what you are trying to do. It is not clear from your description what you need.
5 REPLIES 5
Costantza
6-Contributor
(To:Costantza)
I have this mold and I am trying to remove the material around it as much as I can (so I will not have a lot of wasted material). I am now trying to achieve this with the Swept Blend function, but when I am trying it, it removes only the inside material and not the one around. How can I do that?
StephenW
(To:Costantza)
Costantza
6-Contributor
(To:StephenW)
Sorry, maybe something went wrong when I was uploading the file. I hope this time to upload it correctly
StephenW
(To:Costantza)
Yes it work. It is a Creo 5 file and I haven't installed Creo 5 yet. Hopefully someone else will be able to help.
Are you talking about trying to be left with the core and cavity like in mold design?
I don't think the Swept Blend will get you what you want because you will need some trajectory and it will interpolate between sections.
Is this an assembly? Because if it's a part, why don't you turn the extrude into a cut?
You could also select the surfaces that form the extrude, copy and paste to make a quilt, and then solidify or thicken the quilt depending on your intent.
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
