When someone has used the wrong model in an assembly you can easily switch it out by creating an interchange assembly. When someone has used the wrong model in a drawing view I just checked today using Creo 3 and you cannot switch out by an interchange (only current family table members). Anyone know a workaround for this or is this a feature request being born?
I think that's going to need an Idea submittal.
Here is a similar topic:
https://community.ptc.com/t5/Creo-Modeling-Questions/change-model-referring-in-drawings/td-p/324283
It looks like this is supposed to be in Creo 4.
