Hello All.
I'm currently working in Creo 4.0 M030, and the config option Switch_dims_for_notes is not working at all, when I set it to yes the drawing does not show me dimensions as the symbolic format (dXXX:X), it keeps showing me the numeric values. Do you know if it is a version bug or maybe I'm doing something wrong.
Thanks in advance.
If I read the description right, it is only during note creation.
Have you considered submitting a support ticket to PTC?
It is a known bug to PTC.
Does it have a SPR assigned and a planned fix date and affected platform/versions, MaheshSh?
Please elaborate.
Yes, it is a SPR issue however no planned version details available as of now.
Hello.
Thank you all for your replies.
As MaheshSh answered, it is a bug known by PTC, the answer they gave me is that they have a SPR about this and they will look into this (I don't know when); at the moment I'm pressing Switch Dimensions to see the DXXX:X of the dimensions while I'm creating the notes in the drawing, I don't like this but is what we have.
Thank you.
