Table Pattern of Holes
Sachin
7-Bedrock
I am creating a pattern of holes with "table" definition.
As soon as I define the table pattern, it is not allowing me to edit the definition of the pattern head hole.
I mean, if i have created the table pattern of the clearance holes, and now I want to change them to tapped holes, then in that case, table pattern doesn't allow to alter the hole type.
Is there any solution to this?
Sachin
1 REPLY 1
TomD.inPDX
(To:Sachin)
The problem lies in the fact that when you change the hole type, it deletes the original and replaces it with a new hole. That means the pattern references no longer work. Serious oversight in the hole feature on PTC's part but I am certain it works to specifications. This is true with axis references as well.
