Table>Create Balloons>By Record>
wfalco
Using:
Table>Create Balloons>By Record> (select bulk item in BOM).
I get a balloon with qty. However, the qty is 1. We use A/R. It was established in the BOM relation and does report as such in the table. But not in the balloon.
Can that be changed from 1 to A/R. My bet is no.
WayneF
2 REPLIES 2
dschenken
(To:wfalco)
You can create a custom balloon that reports any field that is in the BOM table.
http://support.ptc.com/help/creo/creo_pma/usascii/#page/detail%2FCreating_Customized_BOM_Balloons.html
Kinda figured I'd be headed to custom. Thanks! I will check this out.
