Text Font Problem
John.Pryal
Text Font Problem
I have a problem which is bugging the life out of me. I have created a text font of my own using Font Creator & placed it in the Pro Font Directory. It semms to be 99% ok except for 2 characters, the number 4 & the letter A. Let me explain what i am doing with this font, i am simply projecting text onto a flat surface, just plane sketched text, there is no need to extrude this text, it is purely a cosmetic thing. The problem occurs with any existing models i have, i type out the text i require & everything seems fine unless i need the number 4 or the letter A. At first i thought it might be problem with the font itself, (i am by no means an expert on using the Font Creator software) but through messing around i realized that this does not occur with any new part i create, only with existing models, made prior to this new font being included. I also realized today that it works fine for all drawings both old & new, i create a note, change the properties, select the new font & everything works just fine, its just with models. Anyone have any idea what could be causing this?
Kind Regards
John
0 REPLIES 0
