I am just transfer to Wildfire 4.0M140. When I print 2D drawings into PDF files, I found that text symbols, like "±","°", all display as messy code.
A test drawing is attached. "drw0001.drw" is proe drawing with a note. "drw0001_3.pdf" is printed in wildfire 3.0. The text symbol display well. "drw0001_4.pdf" is printed in wildfire 4.0. The test symbol display as messy code.
Anyone can help me to make text symbol display well in wildfire 4.0? I don't want to stoke all fonts, it will looks ugly.
Thank you very much!
Try printing to a Postscript file (as ProE usually does) and convert that to a PDF, e.g. using Ghostscript.
If that works, try to set up a printer which does this automatically.
In this way, it does use True Type fonts in PDF, just same as "stoke fonts" option in proe pdf dialogue.
but, it looks like the only way currently.
Thank you
In Reply to Arnold Collett:
CutePDF Writer works well.
Arnold
typo, "does not use True Type fonts"
sorry
In Reply to Bamboo Liao:
Thank you
In Reply to Arnold Collett:CutePDF Writer works well.
Arnold
If you're working with Wildfire 4.0, use the version M120 - there the misrepresentation when using TTFs shouldn't be.
Regards, Domenic
I found the root cause. The PDF creator of wildfire looks like to read the windows regional setting and adjust the code in pdf automatically.
So, you need to add a environment variable "lang=eng" in you systemto make proe identify itas english region.
I test it on wildfire 4.0 M120,M140, wildfire 5.0 M040. They all work well.
also, change to M120 can't slove the issue on my machine.
In Reply to john dugan:
I confirm the use of M120 without problems. Symbols in our Pro/E generated PDF's appear correctly in our drawings. FWIW, we use Arial True Type on our drawings.
