The "branch" command does not allow me to select the line to connect the tubes
Jonathan_info
The "branch" command does not allow me to select the line to connect the tubes, what could be happening?
Branch-Piping.mp4
Video Player is loading.
Current Time 0:00
Duration 0:00
Loaded: 0%
Stream Type LIVE
Remaining Time 0:00
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    Hi Jonathan...
    It appears you're trying to "branch" into the same pipeline you're already running. You need to branch into a DIFFERENT pipeline. Start a new pipeline and route a small piece. Then you will be able to connect to it using the branch command.
    Thanks!
    -Brian
    2 REPLIES 2
    Hi Jonathan...
    Thanks!
    -Brian
    Hi Brian
    Your comment helped me a lot, I did exactly what you suggested and it worked perfectly
