I have some parts that when they are assembled have to be indexed to a fied position. Can somone share how you would describe this on a drawing?
When the male threaded part is assembled into the mating part, it will lock to a surface inside the mating part. I need to control the orientation with the thread starting angles so when they lock they will be indexed to the correct point. I used the default thread in pro so I just pointed to the center axis of the part and said that this where the "full" thread starts. I am being told by the engineering manager that this is not good enough?
