Happy back-at-it gang,
Are we still hamstrung by our bestest, fastest, most bomb-diggetyest hole feature not allowing a thru hole with a thu all thread?
Could this be a license thing....or a dreaded config option?
FYI.....I am in an assembly mode and it seems it still will not work after all these years.In part mode it's allowed and works fine. I don't do a lot of holes so Iwas surprised to find it's still not allowed to go thru allin .asm's. I don't understand why we still do not have this ability since the assembly model features are not affecting the parts in any way. The ATB "should" have a great grasp on this and should allow it. <sigh>
I retract.......Mr. Brattoli has the magic. Use the drag handle to tag the depth to the vertex of the I.D. The thead follows. All other bets are off.
I double retract......the thread is still not "thru all" even dragging the handle. Back to square one.
And for those that may need it, here is the location ofcosmetic in assembly mode to add the cosmetic thread as stated in PTC's work around.
There is a "match" that will automatically "know" what thread size to add if you choose the hole feature as the reference.
Happy Threading my friends.
