hi all,
when you do a repport analysis with TAE, it's created in the PTC CREO working directory.
With PTC Windchill, why the repport analysis is not created? PTC CREO work by default in a workspace, but still have a working directory used for several applications (mecanism, simulation, ...)
thanks,
Ron
ok I found the SPR:
https://support.ptc.com/appserver/cs/view/spr.jsp?n=2826225
and there is no fix plan schedule
ok I found the SPR:
and it's solved with CREO4 (and/or Windchill11)!
