Tooth space milling
ptc-5036838
Tooth space milling
I have made an assembly composed of a gear and hob with gear mechanism (see attachment).
Now I want the hob to remove the material continously when it intersects the gear blank.
I would really appreciate it if anybody can help me.
Best regards
Emanuel
6 REPLIES 6
Hello Emanuel and welcome to the forum.
I am going to make two assumptions which you can clarify.
1. You are not using the manufacturing extension
2. You want to show the material removal as an animation
If you only wanted to make the cut, obviously you can do this in many ways, even at the assembly level by making an assembly cut.
To make this an animation, it is more problematic. The difference is that you will be changing the gear which requires regeneration between frames.
Let me know if I'm on the right track and we can look at options.
Making the cuts continously is going to end up as an approximation. Intersecting the cutter with the blank at closely spaced steps may be close enough. What is the desired outcome?
Animation of step-by-step cutting is easy enough - either create a trail file that saves a frame after each cut or drive it from AutoIT or similar scripting tool.
Above all I want to show the material removal as an animation, but I also want create the true tooth geometry without any gear software.
I have already tried the step-by-step method, but the result is a more ore less rough tooth surface:
Thank you for the hint with AutoIT.
Best regards
Gear teeth profiles still get me but once you get the profile of the hob and the motion that it follows (I'm assuming is it a straight plunge), you can use mechanism to built a series of videos (output as .BMP files) for each depth of the cut you need to make.
Behind the scenes you need a few things:
1. You will be making the cut at varying depth in the assembly. You need to decide how long you want the process for each tooth to take place. This tells you how many frames you need to capture at say 25 frames per second. If you want the full tooth to be cut in 10 seconds, you need 250 frames! You have what... 20 teeth? so that is a 3 minute 20 second video with 5000 frames.
2. Since you know the depth of each cut you can make family tables to cover the depth of each frame. You also have to decide the "cutter speed" if you want to see motion of the hob during each frame. This can be set up with Mechanism so you can go back to your 250 frames and decide how many of those frames will be cutter motion.
The hardest part of the animations is planning the storyboard. What do you need to happened with each frame. I suggest capturing the BMP files and stitching them together after you have them all captured. This makes for the best seamless animation I've found so far. You can run make several captures each with a different depth. If you want to cut all 20 teeth, you will have to rotate the gear (a few frames for that) and do it again.
I know there's got to be an easier way but I can't think of one in core Creo.
Thank you Antonius but that's exactly the same method I proceeded.
Unfortunately it is more than inefficient and the result leaves a lot to be desired.
Isn't there any other possibility to solve this problem?
regards
I'm going to make one off-beat method that might just work depending on the display mode....
What if you overlay two (or 3) fully developed gears and slowly rotate then away from each other? They would begin to appear solid, and as you spin them "apart", they would appear to be having deeper grooves cut into them. In this method, it is a single mechanism setup for each tooth where the cutter rotates and plunges while the gears follow a custom "indexed" profile.
Again, are you capturing all the teeth being cut, or just a single cut? For the following cuts, you need to modify the "blanking" gear so it doesn't obstruct the previous cut. This reduces the effort from 5000 to 20.
