Trailing Zeros
ptc-5124766
7-Bedrock
Trailing Zeros
Hello all!
I have a question about the trailing zeros in the drawings in Creo 2.0. Is it possible to show the trailing zeros on an individual dimension only? Some of my customers use the trailing zeros to signify a given tolerance range (for exmaple .00 means +/- 0.02, .0 means +/- 0.1 etc). I don't want to change the global settings of the drawings however, because only a handful of the dimensions require them and if I do I'll have to change the decimal places value of all the other dimensions. But I don't to do this because if later the associated model is modified, the drawing will not show the correct dimension (example: if I change the decimal places value of a dimension 31.00 to 0, in order to show 31, then if I or anybody else modify the model so that the value is 31.2 it will still show 31 on the drawing).
0 REPLIES 0
