UDA - datum field point
Dussan
Hi everybody,
I´m trying to solve this problem. I usually use the datum field point to create a user defined analysis for measuring the distance between datum and curve and than I got a nice data to export to excel file. Now I trying to do the same, but on the surface. I´m looking for a solution how I can save or obtain matrix of data from that. In attached file I showed to you what I did, but I dont have an idea how I have to continue. Any idea?
0 REPLIES 0
