Unexpected Exit when completing a change to the drawing program
DougPurtill
6-Contributor
In both M030 and M040 after making a change to the drawing program, save, done, done/return the application will exit, (crash).
To reproduce:
In a .drw file select the Tools tab,
select the Drawing Program button,
select Edit Program in the DRAW PROGRAM Menu Manager,
select File Edit in the EDIT PROGRAM Menu Manager,
make the necessary changes to the program
select File, Save and close the program or close the program and select Save from the prompt,
select Done in the EDIT PROGRAM Menu Manager,
select Done/Return in the DRAW PROGRAM Menu Manager and Creo Parametric shuts down.
Note:
If you skip the last step and select something on the ribbon the application will remain open.
an issue has been created with PTC
Doug Purtill
Creo 1.0 M030 and M040
No Windchill... Thank God!
Update!
The Windows 7 display theme was set to "Classic Windows". After I set this back to the default Windows 7 display theme the problem went bye bye.
Doug P.
