Anyone know of a good way to select a generic and all it's family members for unlocking in your workspace?
This is an assembly with hundreds of parts and the names of the family members are not concurrent.
So the easiest way I have devised is to open the part in Pro Engineer and then select File>Unlock.
Then open each family member from the family table editor and then select File>Unlock.
There has got to be a better way!
Best response I got was:
You could do a “CTRL-F” search for the base name or number, then
select all of them, add them to the right side window, then unlock.
