Unused Paramter will not delete
jlippeth
I have a Part parameter that will not delete.
History;
I use a UDF to place a steel stamp on the model
The text in the steel stamp extracts PROE_FILE_NAME and other parameters
All works fine no prob there.
But for testing reasons I want to remove all part parameters and relations.
I delete the UDF feature and all parameters and relations
Two Part Parameters remain and will not delete
Any advice?
Jeff Lippeth ▪ Mold Design Engineer
NyproMold, Inc.
955 Tri-State Parkway, Gurnee IL 60031
144 Pleasant St, Clinton MA 01510 ▪ www.nypromold.com
5 REPLIES 5
TomU
(To:jlippeth)
If it won’t delete then it’s being referenced somewhere. Right click on the parameter and pick ‘Info’, ‘Driven By…’ or ‘Driving’
[cid:image002.png@01CFAC08.64C917D0]
mlocascio
(To:jlippeth)
Those 2 parameters are not going anywhere.
TomU
(To:jlippeth)
One way or another, ALL parameters can be removed!
If these are used by a PDM system, simply back up the file to disk, disconnect from the PDM system, and then turn on the config.pro option ‘allow_create_pdm_param yes’. Delete away!
Tom U.
More info,
We do not use a PDM system
Looking at the Source, the Parameter belongs to Sketch Text, uhm yea I deleted that feature.
I have restarted Pro just to clear Ram, still can’t get it to delete.
Also this part has no other sketches and or Relations
In fact I tested on a new Part with the same results
I’ll keep digging
NyproMold, Inc.
▪ P 847.855.2226
mlocascio
(To:jlippeth)
(I will be waiting for the REST of the story on this one)
