18-Opal
October 26, 2011
Use a parameter value in a file name?
  • October 26, 2011
  • 2 replies
  • 1779 views
Hi there,
Anybody ever insert a Pro/E parameter value into a file name automatically?
What I want to do is export / Copy As to a STEP file, but include a Pro/E parameter in the filename. The revision for example.
-marc
CAD / PLM Systems Manager
We do so here to append the revision parameter automatically. It's not
a simple process. We use a series of nested mapkeys along with nested
batch files to process the output.
Our method goes something like this:
1. Create a temporary folder on the server
2. Output the file in the desired format to the temporary folder
3. Save the parameter information for the file to the temporary
folder as a text file
4. Use a batch file to parse the text file for the desired
parameter ('revision' on our case) and extract that parameter value to a
variable
5. Use a batch file to find the name of the file that was exported.
6. Use a batch file to create an final output folder named with the
date and the file type (111027_IGES for example)
7. Use a batch file to rename the output file
<filename>_<revision>.<type> and move it into the final output folder
8. Use a batch file to clean up all the temp files and folders
I can give you more detail if you want, but that's the gist of it. Your
process may vary based on your parameter names, server structure, etc.
Doug Schaefer
Does anyone know the config option to have the inches amd millimeters buttons selectable when creating a new format?
Stefan
[cid:image001.png@01CC94B0.2983A4F0]
