What is the procedure for loading in a standard set of user-defined parameters into a part?
I've tried Tools>Parameters and then create the user defined parameters
Next: File>Save Configuration As:rp_config.xml
Next: Open New Part>Tools>Parameters>File>Load Configuration:rp_config.xml
The User Defined Parameters do not show up in the list,...just the Default Parameters?
Hi Jolene,
Take a look at the following article for further information on how to copy/export parameters from one part and import to another part:
If you are not able to access the article, please create a user account here. The short answer is to copy & paste them. The long answer is below:
Amit
Hi jkmett,
I had the same problem as you, but I was able to solve this by importing/exporting data as a .xml file instead of loading/saving the configuration. This is also in the file dropdown in the parameters window.
Best,
Ben
