Using IFC in Creo
NM_12143244
2-Explorer
Using IFC in Creo
Hi, I would like to know if I can create IFC files in Creo version 10.0.3.0 with 2 license which has subscription and 9 license which do not. I want to create BIM files using IFC but before I buy it I want to make sure that I can use it in my current Creo version.
Kind regards
2 REPLIES 2
Hi @NM_12143244,
Thank you for your question.
Anurag
It looks to me you have been asking your question in the wrong section.
  • you are asking for Creo version 10.0.3.0
    BUT
  • you are asking in the Creo Element Direct Section (which is for Modeling / Drafting, but not for Creo (Parametric) )
That's why no one can help /answer you here.
May be admin/moderator can move your issue to the right section within the ptc community.
● PE80+90@home ● W10 Pro Build19045.6466 ● Drafting 20.6 + Modeling V20.6+7 + Windchill 12.1.2.6@job ● brain 6.3 ● Stift+Zettel V8.42
